I tried to search this but the damn search thingy wont work!
Anyways, i've got this re-accuring misfire problem. I've done
just about everything i can think of, checked all the grounds
to the ignition box, engine, etc. Changed coil, all new MSD
wires, new distributor cap, plugs, etc. And it goes away for
a while, then it comes back some times and then goes away.
Its pissing me off very badly, especially when i replaced cap $25,
wires $89, Coil $61, plugs about $30...i've got a Hi-6 ignition box,
i replaced the Crane Cams coil with an MSD, i've also added fuel
injector cleaner and checked the wiring harness to the injectors.
Oh and the distributor is a stock unit, i also replaced the rotor twice.
One time i bent the little metal tab on the rotor up more so it contacted the pickup on the cap that comes from the coil and the misfire went away for a while, then a couple of days later it came back, i tried it again to no avail, What the hell is wrong with this?
Am i forgetting something?
amnit:
I was taking something off my fire wall and i had a damn magnetic tipped screw driver, well my upper intake was off. (see where im getting at?) Well the screw fell off and right down one of the ports, i should have had duct tape over it, but i was just taking a useless screw loose, didn't think i would need to cause i was about to put the intake back on. I tried running a magnet down it...but of course, the valve was open! So....you get the idea, but ill try the spark plugs, i liked the autolites better anyways.
Oh well. Im in no hurry, my tranny's in the shop and i got my license suspended for reckless driving (and thats how my tranny got broke, dont ask
) But thanks for everyone who posted on the misfire question...i guess it's fixed, if not i'll post again with the new set of problems....
