My car ran great, then after swapping in a T5 from my Tremec, I have a bad miss at idle. If I give it any throttle at all, it revs smooth and drives fine. It's only at idle. I can feel it through the seat when it does it.
When I installed my S/C I changed the cap, rotor, plugs and wires. My fuel pressure is set to 38 psi, I moved it around a little but no change. The MAF is stock but the wires are clean. I have a Pro M going in on Monday when I get my tune.
Is it possible that one of these old 19 lb injectors got damaged by the FMU? I haven't really seen any kind of REAL boost yet(anything over 5psi), but I did see around 60-70 psi on the gauge while in boost.
Like I said, either it didn't do this before the trans swap, or it did and I just feel it more now because I might have disturbed the motor mounts making them sit different and transfer more vibes through the body.
Should I just go have it tuned with the new injectors and MAF and see if it fixes it?
Also, I changed my TPS and there was no difference.
