Figured I would update those who were curious and tried to help me...it was MUCH appreciated, yall got my thought in different directions. Anyways I figured I would try to narrow it down to the open or closed loop systems, so I disconnected both O2 sensors and I'll be damned, it's cured. It idles differently, more consistent.....it drives much smoother, it has no misfire whatsoever, no backfiring whatsoever, and runs very good at any throttle position.
I've checked the sensors themselves, the O2 ground, the salt/pepper shakers...I suspect a wiring problem/short somewhere in the harness before it meets the ECU, somewhere behind the firewall, but I can't say for sure. All I know is that running on a stock fuel map, it runs beautifully, no pinging, not overly rich, and WOT is obviously the same as it was dyno-tuned for, so I really have no more modifications to make, other than removing the sensors completely and installing plugs in the bungs, and setting them upon a shelf.
Thanks for the help guys, this has been a LONG-TERM problem and I'm relieved beyond imagination for finally solving this...
