Miss in the engine
  • Thread starter Thread starter JBeezy53
  • Start date Start date Mar 5, 2006
JBeezy53
559
Sacramento, Ca
Mar 5, 2006
  • Mar 5, 2006
My engine has always had a miss in it and I am not sure what it was. I have changed the plugs, wires, cap, rotor and added an Accel 300 ignition system. I have probably done other things that I can't remember. I will be adding a new coil soon and hopefully a maf. Any ideas what else it can be?
bill302
2,131
alabama,gadsden
Mar 5, 2006
  • Mar 5, 2006
run a compression test on each cylinder and post results
bill302
2,131
alabama,gadsden
Mar 5, 2006
  • Mar 5, 2006
click on link below,here is some good info. and instructions on how to properly run a compression test and what results mean....you can buy a good compression tester at wal-mart for about $20...
http://www.pumaracing.co.uk/comp.htm
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 5, 2006
  • Mar 5, 2006
it maybe as simple as a bent pushrod aswell. anychance you hear a top end tick?
HISSIN50
34
129
Mar 5, 2006
  • Mar 5, 2006
You can also run a cylinder balance test as part of the self diagnostics. If you have a consistant miss, that test should find it. The test doesnt tell you what the issue is, but it helps pinpoint a cylinder, which saves time.
Good luck.
Mavrick
2,264
Collingwood, ON
Mar 5, 2006
  • Mar 5, 2006
The plugs should let you know which cylinder has the miss.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
  • brandyn200
  • Jun 20, 2026
AeroCoupe
