  • 2005 - 2009 Specific Tech
missfire
  • Thread starter Thread starter frdfrst
  • Start date Start date Jan 10, 2006
frdfrst
178
phoenix az
Jan 10, 2006
  • Jan 10, 2006
monday car started to missfire between 4000&5000rpm under load,i think it maybe 02 sensers.car has 14300 miles.i run the steeda cia tune.took it out and put it back to all stock,still does it.took it to dealer they don't have a clue yet.ANY IDEAS?
Motorhead6T5
215
Marysville,CA
Jan 10, 2006
  • Jan 10, 2006
Check spark plugs???
F
FL2005GT
100
  • Jan 10, 2006
Was it immediately after a downshift?
frdfrst
178
phoenix az
Jan 10, 2006
  • Jan 10, 2006
no,had car dynoed on sat. and they could not finish as it kept breaking up
turrizt
70
  • Jan 10, 2006
my car did that... it was a bad coil pack and spark plug in one of the cylinders... fixed under warranty and a tsb...
H
Hemidog
  • Jan 11, 2006
I had a 96' WS6 TA that was only a few months old that started to do the samething. Took it to the dealer and they couldn't find any problems, but it would still misfire around 3000 rpm. I ended up replacing the plug wires and the problem was solved. The only explaination I could come up with was that I had one wire with a break in it and only when the turbulence in the engine compartment was enough to move the wire around, causing a gap in the break, did it misfire.
When I was trouble shooting, I figured the plug wires were a cheap place to start and a good thing to rule out initially.
But to tell you the truth, I haven't been in the engine bay enough to remember if the new Stangs even have wires or the pack plugs right on to the spark plugs.
frdfrst
178
phoenix az
Jan 11, 2006
  • Jan 11, 2006
thanks will check the pack&wires again
turrizt
70
  • Jan 12, 2006
tell us what happens
frdfrst
178
phoenix az
Jan 14, 2006
  • Jan 14, 2006
still does it.have to get it in on ford computer
frdfrst
178
phoenix az
Jan 20, 2006
#10
  • Jan 20, 2006
  • #10
found problem,plugs,all 8 were fouled.dealer installed new ones.new car againlol: :
F
FL2005GT
100
#11
  • Jan 21, 2006
  • #11
All of em were fouled? Wow. Did they blame it on the tune, or what?
frdfrst
178
phoenix az
Jan 21, 2006
#12
  • Jan 21, 2006
  • #12
don't know what did it.i had tune out when i took it in.all codes where gone when i tried to recycle the battery.i put octane boost in before i put it on dyno.the tech said if you use any additives that could happen.sencers are real touchy i guess.car runs great again,but i have to call diablo to unlock the preditor fron the mode it went into.
F
FL2005GT
100
#13
  • Jan 23, 2006
  • #13
Glad they fixed it. Thanks for the update.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Suspension Foxbody ride height change after installing new control arms
  • Mhalc1
  • Jan 3, 2024
9K
Fox 5.0 Mustang Tech May 10, 2024
Mhalc1
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
