  • 1994 - 1995 Specific Tech
missing and stalling
  • Thread starter Thread starter shelbe67
  • Start date Start date May 19, 2004
shelbe67
309
May 19, 2004
  • May 19, 2004
I was wondering if anybody else has this problem that could help me. I bought my car fromthe original owner 2 years ago it had 43000 miles and he took excellent care of it he once changed te oil after 300 miles bc he didnt drive it for 6 months and it was time to. well anway when i bought it it had a slight miss i thought nothing of it except maybe just a tune up which i did thoughit did not helpwell now i have been doing more mods and it just amplfied the problem sometimes it feels like it has a slight cam in it whch ouldnt botherme if it did. every now and then the car just stalls for no reason the idle drops alot when i turn the wheel at a stand still. I dont what it is but its driving me nuts any help would be great oh by the way its a 94 cobra intake 1.7 roller rockers,short tubes highflow cat hpipe mac catback cai and afpr
94TURBO5 O
2,509
VA
May 19, 2004
  • May 19, 2004
Does it have an aftermarket cam or not? If is is a stock cam you are having idleling issues could just be sensors like your IAC or TPS. Sometimes its as simple as a vacuum leak.
What are more symptoms other than what you mentioned.
shelbe67
309
May 19, 2004
  • May 19, 2004
no its a stock cam i dont think i have any vacuum leaks i did the intake twice thinking that it might be but it was doing that before i did the intake. i had it hooked up to a friends scanner but it showed no codes
jmuva44
1,338
Richmond, VA
May 19, 2004
  • May 19, 2004
also look at the ACT/ECT (especially) sensors.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 20, 2004
  • May 20, 2004
Hook up a vacuum gauge. Do a compression test. Clean the MAF/IAT sensors. Check all spark plugs. See if any are running rich/lean. Do you smell fuel under the hood at all?
Scott
jmuva44
1,338
Richmond, VA
May 20, 2004
  • May 20, 2004
Also try, just for the hell of it, putting the old air intake setup back on. Could be your computer doesnt like the new positioning of the MAF.
shelbe67
309
May 20, 2004
  • May 20, 2004
i would think that it was the intake but it did it with the old intake also i will try cleaning the maf and the iat though if thats not it what else?
jmuva44
1,338
Richmond, VA
May 20, 2004
  • May 20, 2004
Could be that the MAF sensor itself has just pooped on you. I had tried many different MAFs when mine was acting up all with the same sensor and nothing helped. Then I switched the actual sensor and it was fine. And yes, I did clean the problematic one...several times with electronics cleaner. Like everything else on a car, they go bad at some point.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
