missing and stalling
shelbe67
309
I was wondering if anybody else has this problem that could help me. I bought my car fromthe original owner 2 years ago it had 43000 miles and he took excellent care of it he once changed te oil after 300 miles bc he didnt drive it for 6 months and it was time to. well anway when i bought it it had a slight miss i thought nothing of it except maybe just a tune up which i did thoughit did not helpwell now i have been doing more mods and it just amplfied the problem sometimes it feels like it has a slight cam in it whch ouldnt botherme if it did. every now and then the car just stalls for no reason the idle drops alot when i turn the wheel at a stand still. I dont what it is but its driving me nuts any help would be great oh by the way its a 94 cobra intake 1.7 roller rockers,short tubes highflow cat hpipe mac catback cai and afpr
Does it have an aftermarket cam or not? If is is a stock cam you are having idleling issues could just be sensors like your IAC or TPS. Sometimes its as simple as a vacuum leak.
What are more symptoms other than what you mentioned.
no its a stock cam i dont think i have any vacuum leaks i did the intake twice thinking that it might be but it was doing that before i did the intake. i had it hooked up to a friends scanner but it showed no codes
Could be that the MAF sensor itself has just pooped on you. I had tried many different MAFs when mine was acting up all with the same sensor and nothing helped. Then I switched the actual sensor and it was fine. And yes, I did clean the problematic one...several times with electronics cleaner. Like everything else on a car, they go bad at some point.
