missing and then knocking
  • Thread starter Thread starter boxcarracer89
  • Start date Start date Sep 25, 2010
boxcarracer89
153
I live in Roswell NM
Sep 25, 2010
  • Sep 25, 2010
I have an 89, has a 347 stroker w HCI. When I start it up it backfires, real little but noticible and then starts knocking right away! new plugs, but the wires are a little old, the timing is set at 12 degrees, it ran ok before, but it started to not have much power in between 2 and 3 rpms it felt like it would kinda bog. then i let it sit for a few days and when I started it back up, and it was knocking ugly!! any advice would be greatly appreciated!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 26, 2010
  • Sep 26, 2010
Does it miss and act up more when it is hot than when it is cold?
Knocking- is it a pinging, rattling sound like shaking BB's in a tin can or more of a thud?
boxcarracer89
153
Sep 26, 2010
  • Sep 26, 2010
its more of a thud! really loud.I didnt let it warm up. it was a cold start i turned it off cause it knocked right away!
BYRDPE
1,556
Memphis,Tn.
Sep 26, 2010
  • Sep 26, 2010
does it sound like its coming from the bottom end? rod maybe?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 26, 2010
  • Sep 26, 2010
Do you have an aftermarket oil pressure gauge? If so, what is the oil pressure when you hear the noise?
boxcarracer89
153
Sep 26, 2010
  • Sep 26, 2010
the oil pressure is a steady 40-45! it sounds like the bottom end. here is a vid if it works. http://picture.vzw.com/pri/gallery/...d=224123006&messageType=saved&msgNo=1&slide=1
BYRDPE
1,556
Memphis,Tn.
Sep 26, 2010
  • Sep 26, 2010
linky no worky
boxcarracer89
153
Sep 26, 2010
  • Sep 26, 2010
damn!! ok, ill re-do it!
boxcarracer89
153
Sep 26, 2010
  • Sep 26, 2010
here it is.
mustangknocking.mp4 video by boxcaracer93 - Photobucket
5.0TailPipeHump
153
Sep 27, 2010
#10
  • Sep 27, 2010
  • #10
Sounds like someone is under there beating it with a hammer, id pin point it where the sound is coming from with an automotive stethoscope and go from there.
W
Whiplash-Smile
18
#11
  • Sep 27, 2010
  • #11
It may just be the Video and the panning of the camera/mic but that sounds WAY too intermittent to be a rod knock.. sounds more like something is loose.. maybe start with the miss and obvious reasons for that - they could be related.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
