missing need help
  • Thread starter Thread starter bcd
  • Start date Start date Jan 9, 2006
bcd
274
arab al
Jan 9, 2006
  • Jan 9, 2006
I got my car put back together last weekend. Ran fine. Drove it saturday and it ran fine for a while then it started to miss around 3grand. Then it got progressively worse the more i drove it. If i unplug the the computer timing plug it smooths off and runs fine. but when i plug it in it starts jumping. any ideas guys. i am at the end of my rope.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 9, 2006
  • Jan 9, 2006
Can you get codes out of the computer to diagnose what is wrong? This sounds electrical (TFI, coil maybe?)
bcd
274
arab al
Jan 9, 2006
  • Jan 9, 2006
gonna try to take it to advance today and get them to pull codes. when i put the motor in i put a new distributor, new cap new button new coil new tfi new plugs plug wires. so i dont have a clue what it would be. i will let them pull codes although when they tried it a few months ago it kept giving them errors
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 9, 2006
  • Jan 9, 2006
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
bcd
274
arab al
Jan 10, 2006
  • Jan 10, 2006
Where is the neutral safety switch? I understand it has to be plugged up to pull codes and there are several broken wires around my transmission so i figure thats why it wont give me the codes
Black1987Stang
1,422
Jersey Shore
Jan 10, 2006
  • Jan 10, 2006
sounds like the tfi to me
bcd
274
arab al
Jan 10, 2006
  • Jan 10, 2006
tfi is new. less than an hour running time since converted to 5.0
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
