Missing
  • Thread starter Thread starter 351carlo
  • Start date Start date Apr 29, 2004
351carlo
267
Philadelphia
Apr 29, 2004
  • Apr 29, 2004
Me Again. The car is now missing at all RPM ranges. I went through the wires, and found nothing. Pulled the #1 plug, and it was sooty,but I still got a spark. Went through and pulled the wires one by one, and didnt notice any difference. Im not sure what could be going on. Any suggestions on tests to run?
Thanks
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 29, 2004
  • Apr 29, 2004
Blown power valve. Test this, by turning the idle screws all the way in to see if it smoths out. You will be reducing fuel, so it should help if the valve is the culprit.
thehueypilot
1,084
Medina,Tennessee
Apr 29, 2004
  • Apr 29, 2004
What kind of distributor are you running? Is it getting the correct voltage?
J
jesserose17
219
Southern CA
Apr 29, 2004
  • Apr 29, 2004
Not if it's a Edelbrock carb...
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 29, 2004
  • Apr 29, 2004
What makes you think it is?
351carlo
267
Philadelphia
Apr 29, 2004
  • Apr 29, 2004
hmm...
It did get better when I put the idle screws in all the way. I put some Autolite Platinums in there, just to give it a new set of plugs (old plugs had maybe 100 miles on them). I think I ruined all these old plugs, because the thing ran too rich.
I got it all back together tonight, and it ran smooth, however it had no where near the power it used to have. It felt like I was running the old 2 barrel. I think I'm trading this Road Demon 625 in for an Edelbrock 600.
J
jscar1968
28
Santa Ynez, California
Apr 30, 2004
  • Apr 30, 2004
Before you swap that demon,check this. I have the same carb. Check the secondary float and make sure it isn't set too high, otherwise it drips gas into the carb. Set it at half the sight to quarter sight glass. Also check that your accelerator pump isn't pushing down at idle. Then try to get those mixtures screws all out to 1/2 to 1 turn. Hope this helps. Let me know.
mustang70
2,445
San Diego
Apr 30, 2004
  • Apr 30, 2004
And if ya decide ya really want to get rid of that carb, I have a 625 Carter AFB I'll trade you.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Help needed - Cranks, no Start
  • sleeping93coupe
  • Nov 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
