Missing
Isaac
15
Carbondale, IL
I have a problem I need help solving, i'll start from the beginning... The car had been sitting for 8 months (had another car i was driving & no money at the time) . The reason I had stop driving it was a blown passenger side head gasket & the c4 was in bad need of a rebuild. I finally had $600 saved up, so I got another T5 to put back in it, intake gaskets, & a head gasket. I put the T5 in, then started it up & made sure it would move both forward & backwards, so i started on the head gasket. Everything went perfectly... for about a month...
The car started off not missing at all, then slowly started missing more & more. It took a month to get it to missing all the time (Mostly @ idle & especially when it was cold). Then about a month in from getting it running one day it just started missing all over the place. It felt like i was driving a 4 or 3 cylinder. Took the car home & replaced the cap, rotor, & plug wires...
Perfect, it ran great... Not one miss... About 3 weeks later same scenario started coming back. I didn't let it get that bad this time. Ordered: aftermarket vpower plugs from NGK (gapped at .046), summit 8mm plug wires, accel cap & rotor, & a summit coil.
Fixed it, back to running great again... 4 weeks later (present time) It's starting to miss again on low end only (thats how it always starts off). & I have no clue what's causing this. I've been told quite a few things & I can agree with some of them, but there is one thing that's really confusing me. Why does it do it a sh** load more when the engine is cold? Somethings that should probably be mentioned that I think would play a bit of a role in this; The timing is set at 20 btc, (I know it's pretty high) & the cam is an x303 with stock rockers, which I think is a definite problem & could have something to do with this. I've been told fuel filter (i can believe it, it's got 50k on it), rockers, plugs fouling, & ignition module.
I've had the ignition module tested, turned out it's in good condition. I'll take the plugs out & get some pictures of them tomorrow, aswell as checking the fuel psi. I'm trying to fix this problem as cheap as I can, which is the only reason I havn't replaced the rockers yet. Things keep breaking or bills take up my money. & i've tried turning the timing down to 16 AFTER the missing had already started, it didn't seem to help much at all.
Thanks for the help.
20 was the most i could get w/o knock on 89 octane & got me the most power. I set it up that high quite a bit before the head gasket went. As for the pickup. I'm not sure where that is. Can you tell me how to get to it? I'd imagine it's under the rotor?
