  • SN95 4.6L Mustang Tech
Mixing transmission fluids...
  • Thread starter Thread starter ocelot
  • Start date Start date Aug 8, 2005
O
ocelot
96
  • Aug 8, 2005
Do they mix fine? Also what would be in there as of now if a shop did the last fluid change?
O
ocelot
96
  • Aug 8, 2005
Oh and its a 5spd 96' GT btw.
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
Aug 8, 2005
  • Aug 8, 2005
Transmission fluids such as Amsoil Synthetic ATF state that it is compatible with conventional ATF fluids. You have to check on the transmission fluid labels. Automatics require Mercon V transmission fluid so therefore mixing Valvoline Mercon V fluid with Amsoil ATF will not cause a problem, though it will dilute the synthetic properties of Amsoil which would be the superior fluid. I'm not sure what fluid a 96 5speed takes, but I'm guessing that your manual either calls for Mobil 1 ATF or Mercon/Mercon V. Check your manual to find out what fluid your transmission takes and look on the bottles to see if they are interchangeable. As far as I've seen, most transmission fluids are compatible with one another.
Quote from Amsoil's website:
"AMSOIL Synthetic Universal Automatic Transmission Fluid is completely compatible with other synthetic and petroleum automatic transmission fluids."
https://www.amsoil.com/storefront/atf.aspx
O
ocelot
96
  • Aug 8, 2005
When I bought the car it didn't come with a manual, anyone else have one that can tell me what it takes?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Aug 8, 2005
  • Aug 8, 2005
the 5 speeds take mercon/dexron 3 ATF. i use Mobil 1 ATF in mine.
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
