MM Clutch Cable, Firewall Adj and Quad install issues....
93 LX
3,081
Norwalk, CA.
I have been having trouble with clutch cables lately so I bought the package from MM that included cable, firewall adj and quad. Well upon removal of the cable and fortes firewall adj and quad I noticed that the cable cut the hole in the firewall. I pryed the hole to straighten it out but it still flexs with the new cable installed. Does anyone know how to support this flexing issue? Also it appears that the cable MM sent me is too long. I can not use the stock bracket to support the cable. Anyone have any ideas?
I agree with using a sheetmetal reinforcement on the firewall. Having it flex or crack is not uncommon.
I didnt even use the cable's bracket, instead making my own 'soft' brackets to hold the cable where I wanted it.
What if i had a 1/8" plate made to screw or pop rivit to the area. Would that work? I mean it is a flat area plus with the firewall adjuster I would be able to adjust for the added firewall thickenss.
