MM&FF Plenum article, have a question.
XStanger
383
In the article they state that the intake is installed with the stock 70mm TB. My question is this TB inferior to other 70mm TB like Accufab/BBK ...? They are the same size.
I am just trying to justify spending more money if not needed.
IT comes down to one thing. is the tb truly as advertised. I have read that the ford 70mm has a taper to it. basically is the manufacture being truthful. I think they should all publish flow #'s.
so in this cas the ford tb may no be a "true" 70mm. I would like to see flow #'s on all the tb's. do the cheaper ones like mac and FRPP flow just as good as accufab or bbk?
if i remember correctly, there were some model years that came with a 70mm stock. i believe it was 02+.
the Ford 70mm t-body is the same as the 65mm except they bored out an extra 5mm right where the blade is.
