  • SN95 4.6L Mustang Tech
MM front lower control arm.....
  • Thread starter Thread starter four.six
  • Start date Start date Jun 5, 2006
F
four.six
443
Corpus Christi, TX
Jun 5, 2006
  • Jun 5, 2006
i want to get these front lower control arms, the forward offset ones.... i dont see a spot for my springs to go? whats up with that? it said something about needing a coil over? what the hell is a coil over conversion?? does that just combine the struts and the springs?? im confused? thanks!!
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Jun 5, 2006
  • Jun 5, 2006
Yes, a coil-over conversion is what you're thinking it is.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jun 5, 2006
  • Jun 5, 2006
Those would be A-arms.
http://www.speedstash.com/infocenter/articles_coilovers.html
I think you may need to get an after market kmember to use coilovers right?
san~man
O-G
A little grass shack on a big lava rock
Jun 5, 2006
  • Jun 5, 2006
Those will not fit on the stock K-member.
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 5, 2006
  • Jun 5, 2006
I think the offsets can, the only difference should be the mounting point pushed over 3/4in
san~man
O-G
Jun 5, 2006
  • Jun 5, 2006
Oops, my bad
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 5, 2006
  • Jun 5, 2006
back up the train..
you linked a pic to the website, since you were there why didn't you just read what they list for the control arm?
The MM control arms can only be used with a coil-over conversion kit; they do not allow the installation of springs in the stock location.
san~man said:
Oops, my bad
no prob bro
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 5, 2006
  • Jun 5, 2006
ok that was dumbest article on coil-overs i've ever read.
Basics
Coilovers will allow you to lower your suspension, and raise it back up with a wrench. Coilovers will replace your stock suspension, and allow your ride to sit on top a unique combination of aftermarket springs and metal parts, working together to lower and stiffen suspension. Using the included raise/lowering wrench, you will be able to lower and raise your vehicles height. Typically, limits are 0-4 inches, depending on most vehicles and wheel sizes however, it is uncommon to lower the complete 4 inches.
the point is to fine tune the setup not to have 'liek omg i have coilovers and i can raise and lower the car yo"
billfisher
1,296
huntsville, AL
Jun 5, 2006
  • Jun 5, 2006
coil over shock. not beside. it's not a modified macpherson.
Stang|ess
Oct 18, 2003
941
Hawaii
Jun 5, 2006
#10
  • Jun 5, 2006
  • #10
honestly, i didnt read the thing. I just posted the first link that i found .
SIR IM SORRY SIR! IT WONT HAPPEN AGAIN SIR!
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
K
Front wheels not centered in wheel well
  • Kpollard
  • May 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 3, 2025
AeroCoupe
