I got a MM steering shaft as the solution to my wonky steering which was definitely caused by a bad rag joint. The part that goes into the steering column won't go in. It gets stuck. When I tried to tap it in, it went in about 1/16" and took me about half an hour to get back out. Yes, I am fully aware of the one concave side. The old one will slide in and out all day long. I tried to grind a little out of the concave side in front of the hole because it looked like it would hang up there. But, no joy. I'm done for the day for other reasons. Anyone have a similar problem?
My first instinct is to go up to autozone, get a $10 rag joint, and send this expensive thing back. Between this and my truck, I have to admit I'm starting to have very limited patience for aftermarket parts that aren't right.
