Moaning/vibration at idle
  • Thread starter Thread starter lancec2c30
  • Start date Start date Dec 11, 2009
lancec2c30
570
Washington
Dec 11, 2009
  • Dec 11, 2009
I pulled the car in the driveway today and once I stopped and let it idle I noticed a moaning noise coming from the trans tunnel. I don't think it is the TOB, because I can also hear that slightly whining.
The noise goes away once you give it the slightest throttle input. It doesn't matter if the car is in gear or not, or if the clutch pedal is depressed. It always makes the noise.
It comes on intermitently, the RPM's will dip slightly and the noise/slight vibration will become much more pronounced.
You can't hear it from outside the car, and barely when you are under the hood. From what I have investigated so far it seems to be at the back of the engine/bellhousing area.
I am tearing my hair out with this car. I think I'm gonna have to sell it and buy an Evo.
HISSIN50
34
129
Dec 12, 2009
  • Dec 12, 2009
Moaning?
It's not a whirring type noise?
Couldn't be exhaust?
T
THOR74
72
Ontario, Canada
Dec 12, 2009
  • Dec 12, 2009
This could very well be coming from one of your catalytic converters (my '91 has 4 of them) which are all up front. Sometimes they fall apart inside, or the exterior heat shields come loose, and can cause sounds like you are describing in that area of the car under those conditions.
Hit your cats with a rubber mallet and check the tightness of the heat shields.
(I am presuming that your car still has cats on it).
Good luck!
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
