  • SN95 4.6L Mustang Tech
Mobile 1 (5-20) GONE for now
  • Thread starter Thread starter xseler8
  • Start date Start date Nov 8, 2008
1 of 2 Next Last
xseler8
619
Montgomery County,Pa.
Nov 8, 2008
  • Nov 8, 2008
Mobile 1 5-20 is hard to come by. What are you using instead of M1 Full Syn. Is 5-30 acceptable or did you switch brands? Thanks, Frank
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Nov 8, 2008
  • Nov 8, 2008
I Always use 5w-30
G
GTRACER88
  • Nov 8, 2008
5-30 is just fine, I use royal purple 5-20.
Skidawg
104
  • Nov 8, 2008
5W-30 would be fine. I heard M1 should return in December.
xseler8
619
Nov 8, 2008
  • Nov 8, 2008
02nightmaregt said:
I Always use 5w-30
I found a PepBoys that has M1/5-20. That's for the replies. I'll keep the 5-30 in mind for the future.
D
darkside03gt
851
Sacramento CA
Nov 8, 2008
  • Nov 8, 2008
I run valvoline syn power 5-30.
the98stang
2,408
Clovis, CA
Nov 9, 2008
  • Nov 9, 2008
5w-20 is thin sh1t....Ford only used it to improve EPA gas ratings. I run 5-30 or 10-30 Mobil 1
T
TURBO80LXCOUPE
20
  • Nov 9, 2008
i use redline 10w30 good stuff
fast97gt
1,082
north carolina
Nov 9, 2008
  • Nov 9, 2008
i use motorcraft 5-20 is that bad???
Skidawg
104
#10
  • Nov 9, 2008
  • #10
One of the reasons, yes.
There's nothing wrong with 5W-20. A good percentage of new cars are recommending it's use.
hotcobra03
poteet,tx
Nov 9, 2008
#11
  • Nov 9, 2008
  • #11
I never used it castro and stp im putting it thru the test 222k and counting
hotcobra03
poteet,tx
Nov 9, 2008
#12
  • Nov 9, 2008
  • #12
I never used it castro and stp im putting it thru the test 222k and counting on an 03 cobra thats still stock
fast97gt
1,082
north carolina
Nov 9, 2008
#13
  • Nov 9, 2008
  • #13
what should i use for mine thats got 172,000 on clock and yes its all original motor and yes i flog the junk out of her. oh ive broke the factory borg-warner t45 and now it sports a 2001 factory tremec t45. i did replace the junk all plastic intake for the one with aluminum coolant runner.
hotcobra03
poteet,tx
Nov 9, 2008
#14
  • Nov 9, 2008
  • #14
Idt it matters much if you keep it clean.but dont u think thinner oil builds oil pressure faster and flows better during start ups?
P
poindexternasty
148
#15
  • Nov 9, 2008
  • #15
I saw a comparison article saying heavier oils produce higher pressure but the difference isn't significant. Thin flows easier but this doesn't necessarily mean higher pressure. Other things equal, thinner oil would have a slightly lower pressure.
02nightmaregt
Jul 1, 2007
513
Southern Indiana
Nov 9, 2008
#16
  • Nov 9, 2008
  • #16
Thats why the recommend it. 5-30 is what all the NEW GT's, GT500's recommend.
xseler8
619
Nov 9, 2008
#17
  • Nov 9, 2008
  • #17
There was something said about the thicker oil could kill the valves. 5-20 is recommended on my year(02). Regardless I let the engine come up to temp before I exceed 2500rpms.(Prochargers instructions)
And I do not do high revs with a cold engine
fast97gt
1,082
north carolina
Nov 9, 2008
#18
  • Nov 9, 2008
  • #18
with or wiyhout a power adder, you should never rev an engine over 3grand ever...even the dumbest people know that
T
TGJ
1,049
#19
  • Nov 10, 2008
  • #19
I use Amsoil in both my TBird( 5W30 ) and Mustang( 5W20 ). I was in stores here recently and would have no problem getting Mobil 1 5W20.
xseler8
619
Nov 10, 2008
#20
  • Nov 10, 2008
  • #20
A salesperson said the Oil Refinery damage in Texas caused a shortage for now. PepBoys & Walmart were out of 5-20 for a while. However, I went to a difference zip code and the PepBoys had 20 qts on hand.
1 of 2 Next Last
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
