  • SN95 4.6L Mustang Tech
mobile 1 oil
  • Thread starter Thread starter mat82284
  • Start date Start date Aug 16, 2005
M
mat82284
889
  • Aug 16, 2005
i bought some mobile 1 oil 10-30 for my car i live in sacramento california where its mainly 100 here. will this oil be ok or should i run 5-20 or is it 10-20???? also should i put 4 quarts and 1 quart of oil or stick with 5 quorts of mobile 1? one more thing my cars a 2000 with 78000 miles.
sgarlic
3,085
Aug 16, 2005
  • Aug 16, 2005
The rule of thumb is run the thinnest oil you can to still maintain adequate oil pressure. I personally would probably continue to run 5w20 until I saw oil pressure problems, but 5w30 or 10w30 should be fine.
M
mat82284
889
  • Aug 16, 2005
ok should i add a quart of lucus to the oil and 4 quarts of mobile 1? i heard lucus is verry efective?
sgarlic
3,085
Aug 16, 2005
  • Aug 16, 2005
At 78k I wouldn't bother adding anything to be honest with you.. unless you're having problems, burning oil, low oil pressure, etc. That's just my personal opinion, I don't care for additives. Give the thread an hour or so and see what others think.
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Aug 16, 2005
  • Aug 16, 2005
About weight ratios; the first number indicates the weight during start up. If its 10w-30, its weight will be a 10 on start up. The second number indicates the weight of the oil at operating temperature. Since you live in a hotter climate, you should be fine with 10w-30.
I would just use 6 qts of Mobil 1. I say six, because although the motor takes 5, I would use some(not all) of the extra qt. to fill the oil filter up before installing it. This helps to reduce friction during start up after an oil change. All in all, it should take about 5.2-5.3qts. You can keep what is left over from the extra qt. around just in case if you ever need it.
Mobil 1 is a synthetic motor oil and already contains any additive packages Lucas Oil stabalizer would have. As said above, if you're not having any leaks or issues, no sense in using any extra additives. Most of them are snake oil anyways.
I personally use Amsoil 5w-30 High performance motor oil with an Amosil oil filter. I like it. I only have to change my oil once a year. I just recently changed it after 1 year of use, and it came out looking almost new. No sign of dirt or foul build up to be seen.
C
comporange04GT
110
  • Aug 16, 2005
Isn't the capacity 6 quarts with the stock pan?
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Aug 16, 2005
  • Aug 16, 2005
I'm not entirely sure. I think the capacity might vary somewhat. I know once someone put 6qts of oil in my car and it ended up spitting about a half a quart out over the next week. I now operate my car on 5qts and what little the filter holds with no problems.
M
mat82284
889
  • Aug 16, 2005
anyone know what size socket is the oil pan socket to release the oil?
Pughman
295
in a galaxy far far away"MISSOURI"
Aug 16, 2005
  • Aug 16, 2005
My 98 runs 5 1/2 qts. filter and all.I also run the mobil 1.And I have got a 114,000....
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Aug 16, 2005
#10
  • Aug 16, 2005
  • #10
I'm not sure off the top of my head. I just know I have a socket set and I try a couple of them till I get the right one. I think its a 3/4, but I'm not entirely sure.
R
Rocketman
730
SoCal
Aug 17, 2005
#11
  • Aug 17, 2005
  • #11
M
mode101
202
Dallas, TX
Oct 16, 2005
#12
  • Oct 16, 2005
  • #12
I have 2 2002 owners manuals. One says 5qts, and the other says 6qts...
One owners manual came with the car, the other is a pdf I downloaded from ford.
which one is right ?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Oct 16, 2005
#13
  • Oct 16, 2005
  • #13
mine usually takes about 5 1/2 quarts give or take
40th GT
916
Lawrenceville, GA
Oct 16, 2005
#14
  • Oct 16, 2005
  • #14
Mine takes 6. Any more and it'll be burnt/emitted.
If you aren't sure how much to use, call up Ford's 1-800 number and find out for sure.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Oct 16, 2005
#15
  • Oct 16, 2005
  • #15
mine takes 6. the drain plug is a 16mm. do not add lucas products to any synthetic.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 4:05 PM
AlexM556
A
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 8 9 10
4K
Classic Mustang Specific Tech Today at 3:02 PM
2Blue2
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
