Mod motor Carnage pics!!!
EPIK
796
LEFT COAST
This is a pic of a Mach 1 motor that had an Eaton Swap. It was an automatic car with the $h!tty cast 6 bolt crank (unlike the manual cars with the 8 bolt Forged Cobra crank), but I doubt that had anything to do with the motors outcome.... I saw this @ AED (advanced engine development) last Saturday, but dont get me wrong, it had nothing to do with any of their work, AED did not build this motor, they are just picking up the pieces.
wow, that scared the chit out of me, I thought for a second before I actually read it(looking at the pics), and thought that your motor had blown up!:eek:
but that does look bad, I guess that's what you get for using a 6 bolt instead of a 8:shrug:
Thanks for being concerened!!!:D Im glad its not my motor, thats 4 sure...:nice:
Ford screwed the auto Mach 1 owners by giving them the 6 bolt cast GT crank...
Why are is everyone talking about and complaining about the cast crank? The powder cast rod is what obviously let go. The rods and pistons are MUCH weaker than the cast crank, so it doesn't really matter what crank you have if you still have the other stock internals.
Also, I wouldn't blame the tuner immidiately. Even with a very conservative and safe pump gas tune, the rods aren't good for more than 450rwhp. If the car was tuned to make 450rwhp in 80* weather, it is already tuned at the power limits of the rods. I don't know where the car is, but around here it is COLD and my car feels fast again. That same 450hp car may be making 500rwhp in this cold weather, which obviously won't work well with rods that are already at the limit.
In my book, that's what happens when you push the limits of what the factory parts are cabable of. Sometimes you win, sometimes you loose, but your always on the line. Ford's quality control ensures the engine will hold up to 300hp everyday, all day. If they see a flaw or defect in a piston or rod, they don't much care long as it is inside their tolerance which they set for 300hp. Because tolerances are all different, some engines will kick a rod at 420rwhp while other lucky people run 480+rwhp for years without a hitch.
Right on the money the crank had nothing to do with this failure. Rods obviously let go either due to bad detonation that pounded on them or just pushing the limits of the stock rods too far. It sucks it took just about everything out with it. Block is trashed, crank may be salvageable but being cast they would be better off going forged in a power adder 4v car. Hopefully the heads didn't take on any damage.
Bill
Who tuned your car darkside? Mine was tuned by speedfreaks in tracy. It runs great and I have beaten the **** out of it since I got it, but I have sence heard some bad things about them. Actually a lot. But my car is great. :D Sorry to hijack the thread but you cant show us all of this and then not tell us who did it. :shrug:
yeah deff had nothing to do with the crank.i have rarely every heard of a crank issue on a 4.6 regardless if its cast or not.the thing that let go there looks pretty obvious to be the rods,especially since they don't seem to exist anymore haha,and maybe some tuning had to do with it but like already stated,those rods are only good for like 450hp at the very max limits.time for an upgrade on the bottom end if they plan to keep the boost going to it.
I would venture to say that the 6-bolt crank had nothing at all to do with it. My guess is that the high static compression ratio, coupled with stock hypereutectic pistons, powdered rods and a poor tune were what killed this engine.
Plenty of cast 6-bolt crank cars out there running more than the Cobra's stock 8psi of boost (mine included) that are surviving just fine. To be honest….I can’t say that I’ve ever seen a crank failure.
Going with the forged crank in the Automatic equipped cars was an unnecessary expense and a correct choice by Ford IMO. The cars shift lower and as such don't challenge the bottom end in the upper RPM ranges like the manual would. Mark VIII's and Continentals ran cast cranks for nearly 10-years without issue, so I really don't see the problem. And since the rest of the bottom end in these cars still suck, having a forged crank in place of the cast most likely wouldn't have made a lick of difference in the outcome.
If you guys would reread my OP, I never said the crank was the issue, I just mentioned that it had the "$h!tty 6 bolt cast crank"...
