More boost in the rain?
  • Thread starter Thread starter oldfox
  • Start date Start date Aug 3, 2011
O
oldfox
234
Aug 3, 2011
  • Aug 3, 2011
It was raining today and I took the Mustang out just to sort of see what would happen, It ran the same until I pushed it. Keep in mind I'm running a roots style blower and the scoop doesn't miss anything. If it's in the air it's going down the blower. Funny thing was where I usually have 8lb boost I had about 9 1/2 or 10lb (little tough to watch the gauge while boosting on a wet road) And it was real responsive also. Denser air or what?
Quack Quack
ID89GT
1,659
18
49
Spokane Valley, WA
Aug 3, 2011
  • Aug 3, 2011
Rain usually means cooler temps, so ya denser air.
J
junkyardwarrior
Well-Known Member
Jan 10, 2011
400
113
63
Aug 3, 2011
  • Aug 3, 2011
ID89GT is correct.
Cooler denser air means more PSI in the intake. It can be cooler or denser or both at the same time. Roots blower only turns X amount of RPM based on crankshaft speed, so if the air going in is denser, it will be denser in the intake as well after the blower.
Case in point: My Lightning (2003). Normally 8 psi boost. Took it on a long trip out to Colorado about 5 years ago. At the top of Raton Pass, I was at 2 psi and on the floor pulling the trailer. 7900 feet above sea level...92 degrees actual air temp means really thin air. Thin air going into the blower means there is less air to be compressed therefore less PSI. That's where turbochargers shine-to an extent. The WG only allows a certain PSI. If air is heavy sea level (or below in some cases), it might only make 10 psi. At altitude in thin air, the WG is still going to allow 10 psi although the compressor has to spin quite a bit faster to achieve the same manifold pressure. Some turbos are out of their efficiency range at altitude with thin air, which then helps reduce power even though PSI stays the same.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
