  • SN95 4.6L Mustang Tech
More EGR BS
  • Thread starter Thread starter Skidzz
  • Start date Start date Apr 20, 2006
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Apr 20, 2006
  • Apr 20, 2006
So today my check engine light came on. I took it to autozone and it came up as "EGR - Excessive flow". The guy tells me that it could either be that the EGR valve needs replaced OR the pressure sensor. He said if the pressure sensor is bad it can give an incorrect EGR reading. The sensor is $70! and the valve is $45. I'm not buying both if I don't need them both. Is there any way to tell which part is bad? They told me that the only way to pin point it is with the type of diagnostic machine that dealerships and what-not have.
46gtsblown
278
  • Apr 20, 2006
try removing the vac line to the egr valve, if you are still flowing exaust gass into the motor you will know because your idle will be poor.
Try taking the valve off and cleaning the carbon out of it to see if that helps.
The sensor is known to go bad so therre is a good chance that is your prob.
You will just have to trouble shoot the system to isolate the cause, If you have a junk yard nearby get the sensor from there to see if it fixes your problem
Dwayne
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Apr 20, 2006
  • Apr 20, 2006
Dwayne
So if I remove the vac line and my idle is poor, does that mean that the valve is working properly? I've already cleaned it twice so I know it's not carbon build up. So I'll try removing the line, but if the idle goes poor after that, does that mean the sensor is bad?
85 Coupe 5.0
817
Kansas
Apr 20, 2006
  • Apr 20, 2006
As stated above, the Transducer is a VERY common problem.
my suggestions,
1. Start car and observe idle, then remove the vac line on the EGR valve, if the idle smooths out, you have a problem with the EGR vacuum solenoid applying vacuum when it should not. there should be VERY little to no vacuum on that line going to the EGR valve at idle. if there is the problem is with the EGR vacuum solenoid or the vac lines aren't on correctly which is impossible unless someone has modified them.
2. You CAN test the transducer if you have a hand held vacuum pump and a digital volt meter. My opinion, just replace the transducer, they are usually the culprit as they go bad alllll the time, although I have seen a few EGR valves and transducers at the same time. The transducer is basically a MAP sensor in disguise. take off the lines going to the transducer, but leave it plugged in. use your volt meter to find the signal return circuit, usually the middle wire. then, use the vac pump to apply vacuum to the upstream port on the transducer. as you apply vacuum the voltage on the meter should change. quickly release the vacuum, the voltage should immediately drop back to what is was when you first started.
I'm sorry, i can't remeber voltage specs for this test. I DO know that when these sensors fail, they usually produce a voltage reading on the signal return of less than 1 volt and won't change no matter how much vacuum you apply, this is a perfect sign that it's bad.
anyone else got some ideas??
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Apr 20, 2006
  • Apr 20, 2006
Ok, so when he told me the "pressure sensor", was he talking about the transducer? Just want to make sure it's the same thing. Where exactly is the transducer located? A picture would help, if anyone has one. I'm sure it's easy to find, but I haven't worked with it yet, so I'm not sure where it is.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Apr 21, 2006
  • Apr 21, 2006
No one knows?
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
