More Electrical HELP! No injector pulse, no spark from coil.
dang man. computer dead or fuse for that circuit blown?
ill be working on it again monday and ill check. Im pretty sure chris checked the fuses on the inside of the car today and under the hood the other day... I did blow the fan fuse today fixing that connector that was pinned wrong. Im just glad it was a miss pin and not something that was ran in the rad support :D
Assuming no other issues, the commonality is the PIP (most likely) or a bad TFI (less likely).
Pull the SPOUT connector and see if you get anything.
