More help with my ignition/steering column
85_SS_302_Coupe
6,945
1,598
223
Northern KY
I tried to find the original thread about this but couldn't find it. I'm having some issues with my key/ignition/steering column. The car will start and run but the key seems to slip backwards or something into the off position just enough to shut it down. I figured that out because if you hold your finger on the key a little bit forward while it's running, it stays running.
Well, i took the column apart some and poked around but the only thing i've found that looks suspicious is a red/green wire that's been spliced into for my electric fan. I'm not sure but i think that might be the off/run wire or whatever. Something is going on with the off/run, because it fires RIGHT over with a turn of the key but it immediately dies...doesn't run at all, just fires over and shuts down. I removed the splice and wired this wire back together but it changed nothing.
So now i'm at a loss. I know a lot about this car but not a whole lot about the electrical aspect because i've never had to screw with it so i'm F'in lost :(
Yeah i have a bad habit of clicking this forum first and was frustrated when i posted...
I know it's electric because of how the key is behaving....When it's running it's RUNNING ya know? Full balls out running like any other time...but the key is the part that's killing it so it's something in the key/ignition area in the column.
Thanks Timeless2 :nice:
Daggar would know the recall years! Pretty sure it was with the key part of the ignition!
