more progress
  • Thread starter Thread starter Edbert
  • Start date Start date Feb 4, 2004
Edbert
3,548
32
109
Austin TX
Feb 4, 2004
  • Feb 4, 2004
See what only a few years worth of Saturdays can accomplish
One more step towards completion, getting the basics and foundation of the electrical system installed.
http://www.edbert.net/trunk.htm
G
GaPonyFarm
663
Columbus, GA
Feb 4, 2004
  • Feb 4, 2004
That looks pretty good... I hadn't seen the starter solenoid mounted in the trunk before, on a mustang. What do you plan on doing with the space behind that panel? Is it lost, or are you mounting subs, or something else in the space.
Edbert
3,548
32
109
Austin TX
Feb 4, 2004
  • Feb 4, 2004
With the top down that space is FULL, completely useless for anything but storing the top.
I decided to try and clean up the engine compartment by elimintating much of the wiring, so moving the soleniod seemed easy and effective.
I can always put speakers in there later, but with the top down (and my ehxaust) I wont be able to hear much. I'm probaly going to roll this machine out without any functional sound system at all anyhow. Just the sweet music of the built 357 to sooth myself
V
vobraman
144
  • Feb 4, 2004
Edbert,
Good job, I was in Home Depot last night looking at some material to do the same thing. Also, about to relocate my battery to the rear of the car. Any suggestions let me know.
thanks,
brian
V
vobraman
144
  • Feb 4, 2004
What was the thicness on the board you used ?
G
gp001
4,401
So. Cal.
Feb 4, 2004
  • Feb 4, 2004
COPY CAT !!!
J/K I thought you were gonna post that you added some neon lights to go with your headlights
Don't know if you are interested, but on mine I didn't like the way the solenoid looked, or the way the cables looked coming off it. So, someone suggested using a solenoid from an early 80s Mustang. All of the posts stick straight out and make it easier to route the wires. Don't have any pics of the new solenoid setup yet.
V
vobraman
144
  • Feb 4, 2004
gp001 said:
COPY CAT !!!
gp001
Do you have some more pic's of that trunk ? How did you support the boards, and what did you use for boards ? Any hints are welcome on this. Need to do mine very soon. I am about to have the six point bar done. I was thinking they were going to take the rear bars thru the package tray ? I guess I better check.
thanks n advance
brian
Edbert
3,548
32
109
Austin TX
Feb 5, 2004
  • Feb 5, 2004
gp001 said:
COPY CAT !!!
But I don't have the aluminum box to keep the severed heads of the Honduh drivers I slay the way you do
Is your photo an in-progress shot? I don't see anything on your solenoid other than the B+ to the starter. I was also considering putting the exterior keyed electrical shutoff that most tracks will require me to have once I break into the 11s, and doing it much the way you have with your daisy-chained setup. Of course I've got quite some time before I'll get there.
Edbert
3,548
32
109
Austin TX
Feb 5, 2004
  • Feb 5, 2004
It is really thin and easy to cut. I'd say it is no thicker than 0.125 inch. I looked into fiberglass sheets, found some in the bathtub section but it was too think, flexible and brittle (would have had to glue the carpet onto it). I looked at plywood but it warped easily and was actually heavier than the fiberboard. The biggest problem with the fiberboard is that it is brittle, and if you saw or drill too fast it will crumble and flake. As long as you go slow it cuts/drills pretty easy and clean.
G
gp001
4,401
So. Cal.
Feb 5, 2004
#10
  • Feb 5, 2004
  • #10
vobraman said:
gp001
thanks n advance
brian
I used 1/8" & 1/4" fiberboard (MDF) for most of the pieces. The 2 bottom pieces extend beyond where the front, sides, and back touch it. I have "L" brackets mounted to the bottom pieces and the front, sides, and back "snap" into the brackets. Somewhat like a door panel would snap into the door. The front, bottom, and back are carpeted using adhesive and a staple gun, the sides are upholstered to match my door panels using foam, fabric, adhesive and staple gun. But, some of this is changing
G
gp001
4,401
So. Cal.
Feb 5, 2004
#11
  • Feb 5, 2004
  • #11
Yes, that was an in progress pic. I have since changed the solenoid to the style I described. I am in the process of finishing the wiring and possibly changing the sides
R
Front suspension upgrade going on one of our 64/5-68 Mustangs
  • Restomotive
  • Apr 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 24, 2026
Restomotive
R
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
