Moroso catch/overflow tank questions.
Fett
766
I bought one today, at the suggestion of a friend, and...well, I don't "get it".
I suppose it is more of a catch tank, and doesn't work like an OEM does. With a hose at the top of the tank and no kind of "straw", how can the radiator suck coolant if it needs it?
Also, where/how should it be mounted...for those who have one?
Ok, nevermind. I was just assulted with a dose of common sense. I was looking online (after searching here first) and noticed that the valve is supposed to go on the bottom and the hose goes on top...which is opposite of how I thought it should go.
Then I found online where people put the hose on the bottom (like I originally thought) and then it works like the OEM one does. I guess I will just leave the top valve open with a small hose pointing to the ground....again, like the OEM one does.
Glad you got it. SOme OEM's do use a 'straw' to suck fluid from the top (syphon system) - I HATE those. A little leak or lack of sealing and you have to wonder if it's working.
It sounds like you'll plumb it with the feed at the bottom - that's how I do them too.
Good luck.
