moroso palm beach
BlueOvalStangGT said:
6.00, are you going tonight? If so I might be there, my buddy just got an 04 GT and hes gonna be borrowing my DR's and we are gonna take turns driving it.
im going. i thought you cant switch cars/drivers. its my first time going so what time should i be there. do you have to go see the tech and do all the paperwork. what time does it run till.
you should be there around 530. even though they say they open at 6 they let you in at 530. also get there early cause of tech if you get there anytime after 6 you will be in the tech line anywhere from 20 mins to an hour(depending on how busy it is). It doesnt matter if the car is in your name as long as you are 18 and dont need your parents signature. You should be able to get 5 or more passes if a cobra doesnt blow out its rearend or one of the rotary roaches doesnt blow up
i just told my dad im leaving work at 3 :D . i have to go back home to and do a few things and then i'll ride out there. i will probally take the pike cause 95 sux with the construction going north especially during rush hour. cant wait to see what my car can do. :banana: is it really worth it to take the 10's outa the trunk? i also have to take the bowling ball out :D
Forget that get rid of all that gas!! I always race with 1/4 or less. If oyu want to bump your timing just add a bottle of torq-o and voila, almost race gas.
damn hour and a half wait to clean up some oil. before that i already had 4 passes. was able to a 5th and last run after the delay but they couldnt give me a time slip b/c they couldnt read my number and the tower couldnt figure out which number the put me as for that run. my first (ever) time run was 2.7 60' with a 15.606 at 95.19 spinning throught first n second. every time after i got it down a lil bit. my best time ( 4th) was14.58 at 97 with a 2.42 60 ft. i need some more practice and i will be getting the gears and some sticky tires with much more planned in the future. i was the only sn95 there in the sprotsman class. i saw a sick ass high 8's supra. wow, what a sight. also a new c6, that was far from stock, wow again. it was lots of fun. going again next weekend to work on my 60' times. i think i did a little better on the 5th run but theres no way for me to tell.
Not a good idea (in the long run) the fuel pump will be working over time trying to feed the motor. It going to get hot and with out enough fuel in the tank to help cool the pump, you shorten it's life span (in the long run) imo.
