Mothers California Gold Clay Bar system
macatak60
46
has anyone ever used it and does it work good. i just went and spent 15 dollars on the thing and I want to know if it works before i open it. Let me know and if it doens't work what is the best wax system to use to remove scratches and swirls and restore the paint and give it that "wet" look
No clay bar kit is going to remove swirls or scratches. Clay bar kits are for removing contaminates that are bonded to the surface like rail dust, tree sap, bird droppings, etc... That is not to say that you should take the kit back as removing bonded contaminates is a good first step after washing the car.
To remove light scratches and swirls you might try Meguiars ScratchX or Meguiars Body Scrub paint cleaner. Either product should be available at your local auto parts store. To protect the paint why not give Meguiars NXT Tech Wax a try?
Here is a pic of my '01 GT with Meguiars Tech Wax.
Pale--you are right! I've learned more here in the last two weeks that I have in a long time! It is amazing how something as "simple" as detailing your car isn't so simple!
Many, many thanks to all of you for your help. I certainly appreciate it!
Still have to finish the inside, but I'm about out of time before Friday.
--Paul
hey man i used mothers clay bar system...works excellent...like everybody says tho its not made to remove scratches and swirls...i used clay bar then megs cleaner wax then megs polish then megs carnuba then megs nxy wax booster...awesome outcome check out my homepage u will see it there with a few other pics
