  • 1994 - 1995 Specific Tech
Motor Build 94 GT
  • Thread starter Thread starter stanger9410
  • Start date Start date Aug 13, 2011
stanger9410
88
plymouth, in
Aug 13, 2011
  • Aug 13, 2011
i have a 94 GT with a 5.0, i have a 95 cobra intake on it with 24lb injectors, 24lb mass air sensor, and a hypertech chip. im wondering if i should start building this motor or find a block to build and have it all tuned at one time. i was thinking about a 347 stroker, but i also have access to a 351 cleveland, anyone have any suggestions???
BlackVert
5,589
9
98
Bethesda, MD
Aug 14, 2011
  • Aug 14, 2011
welcome to the board.
is this your daily driver? can you handle it being down for a while? are you going to do the work yourself? what are your goals? how much money do you intend to put into the project?
people have done the cleveland swap, but it would be a pain. for a 351 swap, your are better off going with a windsor.
99FiveOh
2,051
20
99
J-Ville, FL
Aug 14, 2011
  • Aug 14, 2011
Yes, the Windsor is just a big brother version of the 302. A lot of parts will bolt right over (except your oil pan, flywheel and balancer, and your lower intake manifold and distributor). Plus, the aftermarket support for a Windsor swap is much stronger than the cleveland.
ProKiller
3,064
15
78
PA
Aug 15, 2011
  • Aug 15, 2011
without knowing your end goal, it's a little tough to say what you can do. a cleveland swap is going to be alot more difficult than just about any other option.
stanger9410
88
plymouth, in
Aug 15, 2011
  • Aug 15, 2011
My end goal would be to have a strong motor that will put out about 400 HP n/a then I'm trying to decide if I want a supercharged setup or twin turbos, I plan on buying a block and building it as the money comes so I don't have to not have a car while I'm building it
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
Aug 15, 2011
  • Aug 15, 2011
I would skip the cleveland setup.
ProKiller
3,064
15
78
PA
Aug 16, 2011
  • Aug 16, 2011
i agree. cleveland won't be worth it. and your going two different directions there. you don't build a N/A block that puts out 400 rwhp then strap a supercharger on there. plan the build from the beginning with the blower. parts to make good power N/A aren't the best for the supercharging. perfect example is compression ratio.
stanger9410
88
plymouth, in
Aug 16, 2011
  • Aug 16, 2011
so i need to decide what blower i want and build the motor according to what works best with that blower setup?
99FiveOh
2,051
20
99
J-Ville, FL
Aug 16, 2011
  • Aug 16, 2011
It really doesn't matter which blower or turbo you choose, boost in general requires lower compression to survive. When choosing your rotating assembly and cylinder heads you need to select them with lower compression in mind. (larger combustion chambers in the heads and a dish pistons) You want to arrive at around 8.5:1 compression ratio.
Any descent engine builder can tell you which pistons and combustion chamber size will net you 8.5 CR.
stanger9410
88
plymouth, in
Aug 18, 2011
#10
  • Aug 18, 2011
  • #10
So if you were to do this what would you build
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
R
Transmission for manual swapping a 1994-1995 GT
  • Rembrant
  • Jul 11, 2025
1994 - 1995 Specific Tech Jul 13, 2025
Rembrant
R
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
