Motor Change
5.8 From a 95-97 Truck. You can use your brackets but i like the truck ones better although you would have to clearance the radiator. You'll need a hood. Double sump pan for 351. aftermarket intake (Edlbrock or Trickflow). If you get the 95-97 motor it will almost plug right in....The distributor plug is the same too. You need swap headers.
Chris
