Looking for an answer - I have read a lot of threads and posts trying to figure out what the h_ll I have. Here is the scoop: 1997 4.6 32V dohc motor - fresh bttom end - new stage 3 clutch, beraring, etc.- 5w-30w full syntheic oil- new high volume oil pump - new rod and crank bearings - new rings- blah, blag, blah, anyway the motor was perfect for about 250 miles then one day coming off the highway I noticed a knock. The motor has not even been over 5000 rpm as I was still breaking it in. I have pulled the plug wires one at a time and the knock remains. It increases as the rpm's increase. I thought it to be a lifter (tensioner I guess they call them now) but am not sure. Exhaust is tight with no leaks. Oil pressure stays at 20psi (hot) at idle and climbs to 60 psi when driving. The oil pressure does not flucuate when running. I have tried the poor mans stethescope and it seems loudest on the drivers side on the valve cover bolts by #8. I also listened to the bottom end by the oil pan and there is no noise there hardly at all just a good wooshing sound.
Also - I only rebuilt the bottom end, the top end of the motor is as it came from the factory. (stock) I am not sure what its life was before me with the exeption of knowing it had a supercharger on it before I go it.
I have read that chain tensioners, timming chain slap, lifters, rockers all can give the same noise.
Can anyone shed some light for this Cobra owner???? Anyone have the same problem.
take YOUR time > also I don't know how youo pull the valve covers but it's easyer for me to pull the intake off just for the room. the tool is cheap too I think it's only $30.00
