Motor mount...
Yeah you can you need to diconnect them and jack your oil pan up with a 4x4 or 2x4 piece of wood. Make sure you put them on the right sides they are side dependent.
Jrichker has a nifty write up on doing it.
Make sure that the new mounts' fasteners will accept the stock nuts. Sometimes they change from SAE to metric on parts store mounts. Also I would use vert mounts (ask for any 87-93 vert mount, or any mount for a 93, since Ford switched to the vert captured mount by 93 for all foxes).
You could put an auxillary jack under the bell housing to relieve some stress on the oil pan.
Good luck.
Might have to do it yourself (you probably came across his post while searching about motor mounts before starting the thread anyhow).
I am on dial-up and this site is loading really slow (too slow for me to hunt through threads).
Good luck.
