Motor Mounts
myroc
120
Whats a good motor mount to buy :shrug: ??? Should i just go buy a stock set of motor mounts or is there a good aftermarket mount out there. Cost is not a problem. Motor will have about 400 hp if that helps, and it a AOD.
myroc :spot:
I have the energy suspension motor mounts and tranny mount on my car. I have a stock engine , but I figured if I went ahead and spent the money on the poly mounts I wouldn't have to worry about them for a long time. They are quite a bit stiffer than stock mounts so you feel the engine vibrations more, but nothing you can't live with. They were $149.99 for the whole kit from Summit.
Well I don't know if this answers your question but vert motor mounts should smooth out some shaking and roughness you might have....
So what kinda combo you having with that AOD to make 400 horse....and what kind of times you expect :nice:
David
coupe and vert mounts suck and are a waste of time and money.
Get the poly mounts, if worried about vibration, buy a Lexus to drive.
FYI I have no vibrations with my poly mounts.
