  • 2.3L (N/A & Turbo) Tech
motor problems
  • Thread starter Thread starter bobaganoosh
  • Start date Start date Nov 4, 2007
bobaganoosh
71
flower mound texas
Nov 4, 2007
  • Nov 4, 2007
I have an 88 vert. and the motor spins with a wrench but when i get to one particular spot it stops and locks up.
my nephew was driving out of the driveway when it locked up and died.
any ideas what could cause this.
I think it is possibly a droped valve that is blocking the piston. could it be anything else
mike
E
ethangsmith
227
Manheim, PA
Nov 4, 2007
  • Nov 4, 2007
Did the timing belt snap per chance?
bobaganoosh
71
flower mound texas
Nov 4, 2007
  • Nov 4, 2007
I haven't got into the yet so I guess I'll checkthat first
if it did is there a possibility that some valves are bent
mike
bhuff30
6,037
35
129
Olathe KS
Nov 4, 2007
  • Nov 4, 2007
The engine is not an interference engine. It is physically impossible for a valve to touch the pistons (unless you were to get huge lift cam and/or mill the head a whole bunch for compression). Even then, the valve will compress the spring instead of causing damage to the valve or piston. I doubt this is your problem.
I suppose it is possible a valve broke off...
can you turn over the engine after taking out the spark plugs? You could also stick a screwdriver in the spark plug hole and feel for an obstruciton in the cylinder.
Then, I'd probably pull the valve cover and look for problems. Then, pull the head.
bobaganoosh
71
flower mound texas
Nov 5, 2007
  • Nov 5, 2007
thanks,
I'll keep the post currant for anyother questions
I don't know much about 2.3 or fox body cars in general . I have two older mustang 66, and 71 that I am more familiar with so I'll have plenty of questions as I get into this one
mike
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
Looking for input on Motor choice
  • stevedjarrell
  • May 28, 2025
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2025
Zero fuel pressure @ Shrader, but over 100 PSI at filter
  • Stang337
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 10, 2025
JD1964
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
