Motor questions.Need help!!!!!!!!!!
  • Thread starter Thread starter satanas
  • Start date Start date Sep 15, 2006
satanas
156
Arizona
Sep 15, 2006
  • Sep 15, 2006
Guys I have some questions Im going to get a 81 bronco with a 302 on it. I have an extra 90 5.0 engine. would i be able to swap that engine to the bronco. i looks the same but the only difference ofcourse its fuel injected which in going to go with carb. the oil pan is different and the pulleis are different. myquestion is would it fit my tranny?Or would it be better if i put a 351 on it. from a different bronco and would that fit my tranny?well guy let me know.Two engines to choose from. which way should i go?
9
95GTAODE
200
  • Sep 15, 2006
It will work fine. You will need to swap over(from the old bronco motor) the oil pan, pick-up, fuel pump eccentric, timing cover/fuel pump, water pump, and all the brackets/pulley's. You will have to use the balancer off of the '90 and the appropriate flywheel/flexpate in the later ('82-up) 50z balance for you're tranny. You will also need to change the gearr on the bronco distributer to a brass or steel piece.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
