Motor questions.Need help!!!!!!!!!!
satanas
156
Arizona
Guys I have some questions Im going to get a 81 bronco with a 302 on it. I have an extra 90 5.0 engine. would i be able to swap that engine to the bronco. i looks the same but the only difference ofcourse its fuel injected which in going to go with carb. the oil pan is different and the pulleis are different. myquestion is would it fit my tranny?Or would it be better if i put a 351 on it. from a different bronco and would that fit my tranny?well guy let me know.Two engines to choose from. which way should i go?:bang:
It will work fine. You will need to swap over(from the old bronco motor) the oil pan, pick-up, fuel pump eccentric, timing cover/fuel pump, water pump, and all the brackets/pulley's. You will have to use the balancer off of the '90 and the appropriate flywheel/flexpate in the later ('82-up) 50z balance for you're tranny. You will also need to change the gearr on the bronco distributer to a brass or steel piece.
