motor rebuild
  • Thread starter Thread starter Foxfan88
  • Start date Start date Sep 3, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Sep 3, 2005
  • Sep 3, 2005
Ok as it stands now, i have my 3.90 rearend.
Picking up t5 swap parts tommorrow....
and i will have about 450$ in the bank
Should i get a rearend bushing kit??
I also need to rebuild my motor too.
We will probably rebuild the motor, swap the tranny, and swap rearends all at the same time, should be easier.
how much should a nice solid rebuild cost me??
My longblock i have is a 93, i can get a hold of an 87 camshaft, i am told they are a more agressive cam than the 89 -93 cams
Or i was thinking a b cam.... the motor will be stock for the most part so i dont know.
I think a b cam with 1.7RRs and those 3.90s it would pull pretty damn hard in the upper RPMs.
But the 87 cam with 1.7RRs would be nice wouldnt it, and i would save some money. I would get the 87 cam for free and just need to buy RRs, if i got the bcam, i would be buying the cam and the rockers.
So
bcam + 1.7s
or
87 cam + 1.7s??
Also i should be getting 8 used pistons from a friend. So say i buy the 180$ federal mogul rebuild kit, how much more money should i expect to spend on the rebuild??? besides machined block and heads...
txstang84
1,639
42
69
Tuscola, tx
Sep 3, 2005
  • Sep 3, 2005
a good solid rebuild...ok, you talking full long block, or just short block? short block should run around $1200 for parts and labor...sometimes less, depends of the amount of machine work and how many parts you gotta buy...long block, add about $300 to that provided you're keeping the stock heads...which should include a 3 angle valve job...
what kind and what size are the pistons you're getting from your friend? If you buy the federal mogul kit for $180 (not a bad deal, but it's probably either cast or hyper pistons, they'll work, but you'll be a little limited as far as power adders)
the cam in your '93 b-provided it's an H.O cam is no different that the '87...if you run 1.7's with the stock cam, you'll only gain 0.030" lift...(up from 0.444" to 0.474"), the B-cam already has .480", and adding the 1.7's to it will bring it up to 0.512"...at this point in time, with stock style pistons, it would be a good idea to go ahead and ck piston to valve clearance. not saying that it won't clear, but never hurts to ck. You could also look into getting a TFS stg 1 cam, (intake= 221*@0.050 0.500" lift, exhaust=225*@0.050" 0.510" lift) and just run 1.6's. it's $30 cheaper than the B cam and would probably work pretty well with your combo (stock SB Ford heads like more exhaust duration)
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Sep 3, 2005
  • Sep 3, 2005
i mean i have a longblock from a 93 in the garage, that i am going to rebuild.
the 180 kits are just bearings and seal etcetc, no pistons. the kits with pistons are 280$ and they are hypereutectic.
My friend has a set of 8 forged pistons from an 89 i believe, i might buy them.
A friend of my dads ( who sold me the 93 longblock) is coming over sometime and he has the 87 longblock. Since my hyper pistons on my 93 are bad and one cyl in the block needs to be sleeved, he is going to bring the 87 motor down and we will tear it down. Then he will give me the better of the two motors, like if he has good pistons he will trade me, if his block is good and just needs a hone we will trade. He is a machinist and he prefers to bore out his motors when he builds stuff. He is really nice too, he is helping me out with my motor.
If his pistons are bad i will buy the pistons from the 89 for like 50$, i am sure they are good, or he wouldnt sell them, I will get them checked regardless.
I am wanting to get some RRs, for more consistent valve lift, i hear stories of stock rocker arms that varie from 1.4 to 1.6.
I also really like the B cam, i hear a mustang up close with one and it was pretty nice needless to say.
so i will buy the 180$ kit (bearings, seals and the works)
get the block and heads machines and reconditioned
get some pistons.
B cam
1.7 RRs
rebuild the longblock and then pull my current motor, for the intake and accessories. I will delete the smog and maybe even take off the A/C. Maybe some underdrives later on....
Does that sound like a solid plan??
Who makes and where can i get 1.7 PEDESTAL MOUNT roller rockers??
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 3, 2005
  • Sep 3, 2005
B cam and stock heads will not be alot of fun on the street..your going to loose a lot of low end grunt, and just when the cam starts to really work..your heads are out of their range. Do as you will, but as I said B cam and stock heads are not the combo you need..but if you do, you WILL need fresh valve springs. Send that intake to T-moss if your looking to do any upgrades.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Sep 3, 2005
  • Sep 3, 2005
so will the stock cam and 1.7s perform pretty well??
how about stage one??
txstang84
1,639
42
69
Tuscola, tx
Sep 3, 2005
  • Sep 3, 2005
pistons; go ahead a spring for the new set, putting in a set of used stock bore pistons isn't exactly the best way to revive your engine. I've done it before, and when you hone out the cylinders for the new rings, you end up running more piston to wall clearance...which can contribute to blowby, and it can also make a little bit of noise in the winter (piston slap) both of these are kind of counterproductive to getting the best possible performance out of a rebuilt engine
as for the heads, DMAN is mostly right, but if you can square away a set of GT-40's or 40P's (they can be had for a couple hundred off ebay + shipping), then the b-cam would benefit you a little more, as would the TFS stg 1 cam.
For what it's worth, I ran a cam a little smaller than the B with reconditioned stock heads, and I didn't lose any low end...so, it's up to you, if you want, go ahead and get the cam, and you can bolt of a better set of heads later.
old_blue
1,783
282
124
Sep 3, 2005
  • Sep 3, 2005
TFS stage one would work fine with stock heads since you have that 3.90 rear. I would worry about it. and like txstang said you can just bolt on a set of heads later to help out the cam more. I would rather put a cam in while the motor is out than to have to do it when the motor is in the car. Heads arent as bad, especially if you buy some aluminums later. and I agree with the above post, send the intake to TMOSS. When I get my cobra intake (waiting for just the right price) I am going to send it to him first.
Paul Perreca
1,085
  • Sep 3, 2005
alot of times when you get heads off of ebay, they come w/ 1.6 or 1.7 roller rockers on them already, just sold all together, so look on ebay before you buy any parts seperatly, if your gonna get heads.....
txstang84
1,639
42
69
Tuscola, tx
Sep 4, 2005
  • Sep 4, 2005
tbadair said:
...I would rather put a cam in while the motor is out than to have to do it when the motor is in the car...When I get my cobra intake (waiting for just the right price) I am going to send it to him first.
much agreed, changing the cam isn't a huge pain while the engine is in the car, but, it's soooo much easier on the stand..
how much are you looking to pay for a Cobra intake?
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Sep 4, 2005
#10
  • Sep 4, 2005
  • #10
i dont know if i can afford an intake this time.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Sep 4, 2005
#11
  • Sep 4, 2005
  • #11
Be realistic about how long it will be before you do a heads/cam/intake. A cheaper and just as effective alternative to a used Cobra/Performer would be to port the stock lower and use it with the stock heads - and I'd use the 87 cam with 1.7 rockers (what I run).
txstang84
1,639
42
69
Tuscola, tx
Sep 4, 2005
#12
  • Sep 4, 2005
  • #12
very good point, and if you don't mind losing a little bottom end (actually a pretty good bit of bottom end, you could get the Comp poly upper intake, that thing pulled like a freight train on a friend of mine's car...only problem was you had to get it past 3200rpm-but after that, the only thing holding him back was the rev limiter.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Sep 4, 2005
#13
  • Sep 4, 2005
  • #13
well realisticly i wont do a H/C/I for a long while, at least until i am out of school and have a good job....
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
