Motor Trouble??
I put a new crate motor in the mustang it`s the gt-40 ford racing motor. Look at my signature to see whats all on the motor.....My problem is when I`m crusing around it lower rpms its very jerky...sometimes it`s really bad...I've noticed its always jerky when the rpms are lower then 2000 anything above that it drives good...I have no idea whats causeing this to happen?? any help please:bang:
I know the timing is in ....when i got it dynoed they checked it....i think its at 14 advanced and i have messed with the fuel pressure and it get better when i put it around 50 but still isn`t right....it almost seems like it isn`t getting enough fuel...but I don`t know..i`m at a loss
Spend 2 cents for a paper clip and you can dump the codes...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
index.php
attachment.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is less than $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
If you are having surging idle problems or no idle at all, see "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=698148
for help with your idle problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
All of the info in there is good to apply to low speed problems too.
