  • 1994 - 1995 Specific Tech
Moving radiator back?
  • Thread starter Thread starter 1105
  • Start date Start date May 16, 2004
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
May 16, 2004
  • May 16, 2004
Is it possible to more the radiator back to where the A/C condenser was so I can get more clearance between my radiator and engine?
94TURBO5 O
2,509
VA
May 16, 2004
  • May 16, 2004
I would like to try this also.
I wonder how much cooler our cars will be in temp since the A/C condenser is deleted?
yellow5.0cobra
2,849
In the garage, On the floor.
May 16, 2004
  • May 16, 2004
LOL... uh oh...
What do you mean WAS?
Your throwing out the A/C?
Ahhh.. fabrication my buddy... dont worry you can make it fit if you think a little.
Pete
1105
May 3, 2003
3,841
Daytona Bch, FL
May 16, 2004
  • May 16, 2004
Yes.. A/C is taken out of the car. It didnt work in the first place
OinkAodeOink
3,026
Daytona bch, Florida
May 16, 2004
  • May 16, 2004
only problem is, the filler neck would hit the radiator support up top.. Wouldnt be a problem otherwise, as far as i can tell. Check if theres room in fron of the radiator support for thr filler neck. you could make more room by running a pusher fan in front of the radiator, insted of the stock fan. Unless you can unbolt the stock fans blade and flip it over?
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
May 16, 2004
  • May 16, 2004
OT, 1105, what are you doing with your a/c hoses?
1105
May 3, 2003
3,841
Daytona Bch, FL
May 16, 2004
  • May 16, 2004
keeping them incase I ever want to put them back on
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
