MSD 6 BTM hook-up....how to???
Mike, turn the MSD box over. It has a diagram right there. Like I mentioned before that MSD harness is $17.99 at Summit which makes the install about 10 minutes total. Red goes to the distribution box nut, black is ground and can bolt to anything, vacuum line goes to the bypass valve, plug on the far side gets connected to the retard dial, the other connector just leave zip tied. That's about it.
See that black thing at the bottom left. There is a male nipple right there. Plug the vacuum line in there. That is the bypass valve.
The bypass assembly gets connected to the AFM power pipe. Your sig says you have one.
