craigwhite89gt New Member Oct 26, 2003 181 0 0 Cecil County Maryland Apr 30, 2005 #1 Apr 30, 2005 #1 anyone have a good page for installing a msd on a 89 gt.... Im slowly tryin to figure out how to do it by the diagram...With a blaster coil
notchback Founding Member May 30, 2000 1,950 0 36 St Clair Shores MI Apr 30, 2005 #2 Apr 30, 2005 #2 get the tfi harness...it's 20 bux and you don't need to cut a single wire...2 minute install..plug 2 ends of the harness
2002whitegt Founding Member May 31, 2002 179 12 19 Houston TX Apr 30, 2005 #3 Apr 30, 2005 #3 notchback said: get the tfi harness...it's 20 bux and you don't need to cut a single wire...2 minute install..plug 2 ends of the harness Click to expand... Exactly don't even bother splicing just get the harness adapter from jegs or Summit It's part number 8874, and it's really easy to plug in just connect the colors that correspon to each other and that's it.
craigwhite89gt New Member Oct 26, 2003 181 0 0 Cecil County Maryland Apr 30, 2005 #4 Apr 30, 2005 #4 i figured it out it wasnt too bad
Drew_Carroll New Member Sep 8, 2004 22 0 0 Apr 30, 2005 #5 Apr 30, 2005 #5 would this be so you could put it inside the car under a seat without cutting soldering wires?
notchback Founding Member May 30, 2000 1,950 0 36 St Clair Shores MI Apr 30, 2005 #6 Apr 30, 2005 #6 Drew_Carroll said: would this be so you could put it inside the car under a seat without cutting soldering wires? Click to expand... no, still not long enuff
