S stangman393 New Member Jan 1, 2003 220 0 0 Aloha, OR Sep 9, 2004 #1 Sep 9, 2004 #1 Too cheap to buy a whole set of these just for one. Thanks, Jeff
WaterPog Founding Member Mar 12, 2001 2,201 0 0 Portland, OR Sep 9, 2004 #2 Sep 9, 2004 #2 You can just go down to radioshack and get a resistor. the formula is RPM in Ohms - 1000 so a 7000rpm would be 6000 (6K) ohms. If you take an old module and crack it open you can see the resistor inside.
S stangman393 New Member Jan 1, 2003 220 0 0 Aloha, OR Sep 9, 2004 #3 Sep 9, 2004 #3 Thanks for the tip Eric. How do you get the resistor to stay in the socket? Jeff
WaterPog Founding Member Mar 12, 2001 2,201 0 0 Portland, OR Sep 9, 2004 #4 Sep 9, 2004 #4 solder is your friend bring it by the house if you have issues with it, I can hook it up for you real quick. Oh, and be sure you get at least a 1% resistor, .1% if you can find it, common is 10% and especially at higher values can make a big difference.
S stangman393 New Member Jan 1, 2003 220 0 0 Aloha, OR Sep 9, 2004 #5 Sep 9, 2004 #5 I'll try that. Thanks, Jeff
