MSD A/F Tuner
  • Thread starter Thread starter bmo37
  • Start date Start date Jan 3, 2004
bmo37
2,368
New Jersey
Jan 3, 2004
  • Jan 3, 2004
Anyone see this thing or have one, looks pretty good, you have to splice an o2 sensor into it but it allows you to tune your air/fuel ratio for rich or lean condtions, looks like a great alternative if your low on cash for a some pulls and tuning. Although it can't give you data like a dyno can it makes tuning your car for max hp a little bit easier.
ponycar17
1,367
Upstate South Carolina
Jan 3, 2004
  • Jan 3, 2004
You can get a cheaper version from Autometer (mine was $55)... They splice onto your narrowband factory O2 sensor and relay the signal that the ECU sees. I like my autometer guage a lot... It's not very accurate like a wide-band O2 setup would be, but it's a fairly good guesstimation of your A/F ratio as the ECU sees it... You have to accept the fact that EFI cars will stay bouncing around on the A/F scale while in closed loop mode (normal driving). You only get helpful information at wide open throttle, when the ECU goes into closed loop. I use my autometer with a Pro-M MAF Tuner, and I can actually adjust the A/F ratio to some extent from the cabin of my vert. Get one of the Autometer guages, and if you don't like it, you won't have that much invested anyway...
bmo37
2,368
New Jersey
Jan 3, 2004
  • Jan 3, 2004
wait is this just a guage that wires into the o2 or is it something else, cause i already have and auto meter guage pod with a mechanical fuel pressure guage, and than a mechanical boost guage.
ponycar17
1,367
Jan 4, 2004
  • Jan 4, 2004
Are you talking about this device?... If so, yes it's just an indicator. You can get one from Autometer for $55... A/F ratio meter.
http://store.summitracing.com/defau...ord&searchtype=both&part=msd+air/fuel&x=0&y=0
bmo37
2,368
New Jersey
Jan 4, 2004
  • Jan 4, 2004
no this beast http://store.summitracing.com/partdetail.asp?part=MSD%2D8933&view=2047
ponycar17
1,367
Jan 4, 2004
  • Jan 4, 2004
Sorry man, I linked you to the wrong page... Yeah, your link above is what I meant to link to. And yes, it's just an A/F ratio meter, and not a very accurate one from the way it looks. It just tells you whether you're rich or lean, but doesn't show a good scale of HOW rich or HOW lean. I'd go with the autometer if I were you. The reason that MSD device costs so much is because it comes with a heated O2 sensor, and has to have a heating control circuit. Since you already have an O2 sensor on your car, you can buy the Autometer product, and get a better product for less money... Just my opinion...
You can adjust your fuel pressure, and see a difference in how rich your car is at wide open throttle with the Autometer unit. At idle and regular driving speeds, you'll see the Autometer jumping around because the ECU is trying to adjust for a stoichiometric mixture. That MSD would be total garbage if you ask me... It only has two indicator states, rich and lean...
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
R
please help 87 mustang megasquirt 2 idle problems
  • robbie5.0
  • Jun 2, 2025
Digital Self-tuning Forum Jul 18, 2025
tate302
T
