  • 1994 - 1995 Specific Tech
msd cap and rotor.
  • Thread starter Thread starter Rrich
  • Start date Start date Dec 12, 2005
R
Rrich
184
  • Dec 12, 2005
i got the msd cap and rotor from summittracing.com. It doesnt specify where 1 is. does it matter, as long as i get the rotor and plug wire is in teh same place? thanks, Ryan
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 12, 2005
  • Dec 12, 2005
I have not gotten those cap/rotor kits so i havent had to deal with the problem, but i would think that as long as u kept the firing order the same and made sure the rotor was at the #1 plug when #1piston was at TDC, it should be good to go.
I know a couple guys run those caps on here, maybe they will chime in. Or couldnt u just use those "tabs" on it to compare it to your old cap, and find which post would be #1 if it were to be marked?
HISSIN50
34
129
Dec 12, 2005
  • Dec 12, 2005
I am with Nate - just compare it to your old cap and put a little marker mark or something to denote #1.
Otherwise your method, assuming the proper firing order from your chosen #1, should work fine.
Good luck.
F
fiveo'cobra
241
SC
Dec 12, 2005
  • Dec 12, 2005
i know how that is. I got the msd cap and rotor kit and i used a marker to label the new one while i looked at the old. I tried just throwing it on and putting the wires in same place and i was rewarded with a healthy missfire when i started up the motor.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 12, 2005
  • Dec 12, 2005
mine has a little keyway it slides down onto
94MustangGT5.0
288
Champaign, Illinois
Dec 12, 2005
  • Dec 12, 2005
I'm with you on this one. As long as you don't pull the distributor, it should be as simple as pulling off the cap and swapping the plug wires one at a time to the new cap (there are little tabs that are used to line up the cap on the distributor), then put the new rotor on (it only goes on one way). This is a no brainer, don't make it harder than it is.
BPA
159
S.F.
Dec 12, 2005
  • Dec 12, 2005
im with them.. if your worried you can always pencil in what wire # it is on the top and on the cap
R.J.
813
Warwick, Rhode Island
Dec 13, 2005
  • Dec 13, 2005
I think because of the key way, it can't go on wrong.
C
For Sale Mint 1993 Calypso 5.0 Convertible
  • Chrispy62
  • Aug 22, 2026
Fox Body Mustangs For Sale (1979-93) Aug 22, 2026
Chrispy62
C
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
