MSD dist install help...
  • Thread starter Thread starter 302efi
  • Start date Start date Jul 2, 2004
302efi
273
Sunny Florida
Jul 2, 2004
  • Jul 2, 2004
I using MSD part # 8582 on my carbed notch. Which way does the dist go in ??? Does the MSD logo on the shaft point to the front of the engine or does it face the back ??
TT91
1,536
Paramus, NJ
Jul 2, 2004
  • Jul 2, 2004
HUH? A logo shouldnt decipher which way the dist gets dropped into..Do u know how to properly install a distributor? ...or are you just going with your your instincts...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 2, 2004
  • Jul 2, 2004
here's some generic help...
Take the coil wire out of the distributor. Pull #1 plug, put your finger in the spark plug hole. Have someone crank the engine until it starts to blow air past your finger. Stop cranking, turn the engine by hand (breaker bar on the harmonic balancer bolt, or put the car in gear and push) until the TDC mark on the harmonic balancer lines up with the pointer on the passenger side of the engine. Loose the distributor hold down bolt, remove the clamp, cap and wires, disconnect the wiring harness. Pull the distributor straight up.
The following re-install depends on the engine being lined up as in the previous instructions.
To re-install, turn the distributor rotor to point to #1 cylinder position on the cap. The#1 position is about 11 o'clock if 6 o' clock is the front of the engine. Line the rotor up with it pointing at the #1 spark plug position on the cap and drop it in: you may have to twist the shaft some to get it to engage the oil pump shaft. Then remove the SPOUT connector plug, and use a timing light to set the timing. The SPOUT is the dangling connector on the distributor harness on stangs made prior to 94 and with a computer controlled engine. 10* is stock for most 5.0s' 12*-14* is good for more pep if you are not into NO2 or power adders.
302efi
273
Sunny Florida
Jul 2, 2004
  • Jul 2, 2004
NO, NO, NO you guys are misunderstanding me. The motor has been running about 2000 miles or so and my bronze gear was about gone so I changed it. What I talking about is the BODY of the dizzy. When the dizzy was installed before, the logo on the shaft faced the back of the motor. I thought this was odd, so I called MSD and they said it shouldnt be a problem. I was just checking to see if anybody had theirs in with the logo facing the back of the motor. I know how in the hell to install a dist, it just seems that the body could go in either way.
BTW, this is a carbed car, so the dizzy is different then you EFI guys. I think the carbed guys will know what I'm talking about.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 2, 2004
  • Jul 2, 2004
302 - I think what other's are trying to tell you is that provided there aren't any physical constraints (like the efi wiring harness for example - it limits positioning of the housing) you can stab a distributor with the body facing any way you want. As long as the rotor is pointing at/firing #1 when it should relative to piston/crank position, and the wires are in the same firing order as the cam, then it will work fine.
302efi
273
Sunny Florida
Jul 2, 2004
  • Jul 2, 2004
Thanks Michael, that exactly the answer I was looking for
I had just called the MSD tech line and they told me that it didnt matter either, I just wanted some others info on how they put theirs in.
r6bullet
112
  • Jul 2, 2004
The rotor is the only thing you have to pay attention to. The dizzy can go in anyway you want it.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
  • dan50
  • Jul 18, 2026
dan50
