msd harness extender 6al box
noslow1986
274
oswego Il
does msd make an extension harness. i put my msd box under the cold air intake and the wires barley make it to the coil. the wires run infront of the battery. im using the msd one wire hook up at the coil and want the wires behind the battery.
No they dont make an extender. Are you using the MSD harness that just plugs into your coil? Even if your not just grab some same gauge wire, and solder them together or crimp some connectors on them and connect the wires and your done.
Its not hard, you can always just buy wire and practice. Jrichker has a nice link that has a good write up on how to solder. You just push the two exposed wires together and twist. Then wrap the solder around the exposed wire and just use the iron to melt the solder pretty much, the more you practice the cleaner it will be. You can always just crimp connectors.
