  • SN95 4.6L Mustang Tech
muffler/other anyone help?
  • Thread starter Thread starter RCChopper
  • Start date Start date Jul 6, 2005
R
RCChopper
27
Now stationed in England
Jul 6, 2005
  • Jul 6, 2005
I was wondering has anyone ever cut their factory mufflers off and welded tubing into place, so no mufflers but leaving the factory exhaust. Will i encounter any problems with doing that. the cats would still be on there. Also i know its been asked but i have an 04 GT with the factory 17 inch bullitts and the 245 45 17's on there but its time for new tires all around. i want to go wider in the rear and also i plan on dropping it just with some new springs don't want to get into the full suspension yet. so i was thinking 275/40 in the rear or can i do that all around and then the steeda springs. don't want it to look to low but i do want it lower than what it is right now can you guys help me out. need to order tonight. thanks
Will
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
Jul 6, 2005
  • Jul 6, 2005
I drove around once with just the stock H and it's a bunch of untuned white trash garbage.
The volume and grunt of it is cool, but you gain a lot more respect for what mufflers do along side reducing noise once you hear how craptastic open pipes sound. It's more of a random assortment of noise then a burly v8 sound. Thats what I mean by untuned.
I wouldn't go any wider then 255 on the stock rims, if you want 275 please step up to a wider 9'' rim. They're 245 for a reason.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jul 6, 2005
  • Jul 6, 2005
Straight pipes = the 'neck
R
RCChopper
27
Jul 6, 2005
  • Jul 6, 2005
yeah i know, well i guess i'll just do the muffler thing is it cool to get a set of mufflers and keep the factory exhaust for now, and for the tires. i was checking out a page that said i could safely go up to 275 40 17 on the 17x8 rim
96WhiteNight
303
Carlisle, PA
Jul 6, 2005
  • Jul 6, 2005
Get an off road X or H pipe that will give you a lot more sound then just mufflers, keep the stock cat-back if you need to save cash.
timeless2
Admin Dude
202
154
the Shadow Gallery
Jul 6, 2005
  • Jul 6, 2005
Agreed. The stockers do not sound bad if you keep them and swap the mid pipe for something sans cats.
R
RCChopper
27
Jul 6, 2005
  • Jul 6, 2005
my whole thing is i am stationed over here in england and its hard to find a dyno that i can do a tune at, i figured i would have to i am already running lean from my tb and plenum install.
96WhiteNight
303
Carlisle, PA
Jul 6, 2005
  • Jul 6, 2005
Do the X or H. You won't need a tune from a tb, plenum, and mid pipe. Your computer will adjust for it. The only time you really need to tune the car is when you swap major componets like cams, heads, power adders **** like that.
R
RCChopper
27
Jul 6, 2005
  • Jul 6, 2005
my car hasn't adjusted for it i had the codes pulled and they said i am running lean in bank 1 and 2
96WhiteNight
303
Carlisle, PA
Jul 6, 2005
#10
  • Jul 6, 2005
  • #10
Sounds like you have an air leak then, a plenum and tb shouldn't throw any codes. Check all your connections and gaskets.
R
RCChopper
27
Jul 6, 2005
#11
  • Jul 6, 2005
  • #11
that's what i was thinking too but i can't find anything.
96WhiteNight
303
Carlisle, PA
Jul 6, 2005
#12
  • Jul 6, 2005
  • #12
Get a can of carb cleaner and spary the intake and tb and stuff if you here the car die there's the trouble spot. Trust me i had the same problem i couldn't find anything. A buddy of mine started sparying stuff and we found my tb gasket was cracked.
timeless2
Admin Dude
202
154
the Shadow Gallery
Jul 6, 2005
#13
  • Jul 6, 2005
  • #13
Cheap and effective method of diagnosing many problems...
R
RCChopper
27
Jul 6, 2005
#14
  • Jul 6, 2005
  • #14
cool i'll try it this weekend thanks for the info. what do you think i should do about tires. i would like to go wider in the rear. and what should i do about the front
96WhiteNight
303
Carlisle, PA
Jul 6, 2005
#15
  • Jul 6, 2005
  • #15
go with 255's up front and 275's in the rear. i got 275's in the rear of mine on stock rims ( i think they are either 8 1/2 or 9)
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
