Mufflers For dummies
  • Thread starter Thread starter DanB93
  • Start date Start date Apr 27, 2009
D
DanB93
66
Apr 27, 2009
  • Apr 27, 2009
So I have been searching around here. I'm looking to replace my stock mufflers on my 5.0 with something quieter. I don't want to loose performance but I don't like the rumble unless I'm stepping on the gas. I'm thinking about the Borla Pro XS but what I wanted to know is how much do I have to replace to get the benefits of the new mufflers? I mean can I just get buy the mufflers and put them inline and be good? I doubt I will do many mods to this car in the future, may be a T5 swap. maybe some different gears but that's about it. Thanks
LX302
Stanger
728
Bethlehem PA
Apr 28, 2009
  • Apr 28, 2009
Most catbacks will be louder, not quieter than the stock mufflers.
Dynomax and or Flowmaster 3 chambers mufflers come close, but will be slightly louder. You can just replace the mufflers if you want, but most probably your tailpipes and connecting pipes are rusted to the muffler, so unless you want to have a shop cut and weld them in for you, I would just bolt on a new catback and do it yourself. I personally would go with a 2 1/2" vs the stock 2 1/4". I noticed a slight difference on my stock motor.
But you'll get many varied opinions as to what's best.
Hope this helps.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 28, 2009
  • Apr 28, 2009
The stock mufflers are one piece with the flow tubes and the tails so they will have to be cut and welded.
There really isn't anything out there on the market that is going to be quieter than stock and certainly not Borla. Your only option would be to put a stock replacement muffler on and retain the sound you've got.
Boss91GT-SC
27
Hope Mills NC
Apr 28, 2009
  • Apr 28, 2009
5.0's are supposed to bark, put flowmasters on it.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Apr 28, 2009
  • Apr 28, 2009
The closest thing you're gonna find to a stock muffler for that is a Dynomax Super Turbo muffler, 2.25" offset inlet/outlet. If you want to pick up a little more flow but still keep it relatively stock-sounding and looking/fitting nicely, get a Dynomax Super Turbo cat-back system in 2.5" with the stainless tailpipes - one of the cheapest cat-backs available, but also one of the best-fitting and nicest-looking.
A secondary choice would be a Flowmaster Delta-series cat-back, but I friggin' HATED the fitment on the one Lynn got for her Capri - had to bend and beat and cut and mangle that damned thing to get the tailpipes to line up correctly. They'll also tend to be a little louder than the Dynomax cat-back by just a little bit, and the Flowmaster muffs don't flow quite as effectively ... probably among the worst on the market for flow, actually.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 28, 2009
  • Apr 28, 2009
I have the DynoMax Super Turbo kit with 2 1/4" tails on my Saleen. It is much quieter than Flowmasters, but still louder than stock by a bit. I agree with the fitment. It was perfect out of the box.
D
DanB93
66
May 2, 2009
  • May 2, 2009
Thanks for the replies
MahFiVeOh
531
9
49
Ontario, Canada
May 3, 2009
  • May 3, 2009
Magnaflow is kinda quiet cruising and sounds pretty good when you get on it.I had a Magnaflow catback but i wanted louder so i went with Flowmasters.
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
D
SOLD $300... Borla S-Type axle-back exhaust (like new... was on '08 Bullitt Mustang)
  • D-Tex
  • Jan 1, 2025
  • Exhaust Parts
Exhaust Parts Jan 7, 2025
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
