MultiFunction Switch Compatibility
  • Thread starter Thread starter TenorPlayinGuy
  • Start date Start date Jul 13, 2009
TenorPlayinGuy
1,208
Canyon Country, Ca
Jul 13, 2009
  • Jul 13, 2009
I found a near new Turn signal/MultiFunction switch out of a mustang at the yard last week, and I was just looking at the back pins on both units, and saw a few of them either missing, or moved. Is there a different wiring for the newer units? This came off a 1991 I believe. (can't always be sure when theres no sticker on the door)
But is the wiring different through the years on the multi-function switch? This newer one also has a longer arm, which I like since my 87's is short and kinda behind my grant wheel.
Thanks fellas.
skunk21
1,203
Taxachusetts
Jul 13, 2009
  • Jul 13, 2009
The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-89 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You cannot put an early model switch in a late model car, nor can you put a late model switch in an early car.
I just went through this when my blinkers stopped working a few years back and I didn't relize I had gotten the wrong year multifunction switch, it took alot of post & replys + a look at the 90yr schematic to figure out in the end it was that the pins where in different spots between the years. moving the pins is a huge pia so I sent it back and got the correct year switch. learned something new with hat experience.
TechSteele
60
North Coast
Jul 13, 2009
  • Jul 13, 2009
I tryed useing a 91 in My 89' (before i knew there was a difference)
The turn signals worked and just about everything, BUT, the wipers and washer fluid did Not work.
Useing an 89 on a 93, i am not sure what would happen.
If you switch around the different wires externally from the switch, you can use it.
The differences are internal, so nothing you can quickly change without cutting wires.
TenorPlayinGuy
1,208
Canyon Country, Ca
Jul 13, 2009
  • Jul 13, 2009
The problem I'm facing, is that they do sell a new switch at the zone/Kragen. But they have the same part numbers for both years. 87-93. So what should I do?
TechSteele
60
North Coast
Jul 13, 2009
  • Jul 13, 2009
Make sure you LOOK at the switch they sell for the "89".
I had my mechanic TRY to get one, they kept sending one, but it was for the > 84 < and not the 89.
It was Used in 89, but on Cougars and a couple other cars.
IF it has a little hazard switch on the bottom, it Will Not Work, the wires AND the connectors are different.
Bone yard and Ebay are your best bet, just make sure it came out of an 87-89.
TenorPlayinGuy
1,208
Canyon Country, Ca
Jul 14, 2009
  • Jul 14, 2009
Thats what I was thinkin. Maybe I should spend the bucks and get a LRS piece. If they still sell them.
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
F
Wiper motor relay? Motor? Multifunction switch?
  • Flinchum87
  • Jul 15, 2024
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 15, 2024
Flinchum87
F
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
