Multimeter results: do i have a parasitic draw?
crazyone64
5 Year Member
May 2, 2018
100
Toronto Canada
Car is stored, not driving it right now.
Battery lasts less than a week.
Bought a new battery, still lasts 5 to 7 days.
I've attached the multimeter results if someone could help confirm if I have a parasite.
The short answer is "yes" you have a parasitic draw. All computer-controlled cars do.
I agree that 7-days on a fresh battery is excessive but an El-Cheapo battery with a small reserve can help contribute to that.
One of the first things that I would check is the alternator. If the diode is bad then the battery tries to run the alternator like a motor when the engine is off.
After that, I would begin a process of elimination by pulling fuses one by one and checking the current draw from the battery as you do.
View: https://www.youtube.com/watch?v=KF1gijj03_0&ab_channel=EricTheCarGuy
Thanks for the reply.
It turned out to be 2 areas..
1. I disconnected my car audio fuse holder which is under the hood. That dropped it from 2.6 to 1.8.
2. Under the hood fuse #6. 40a. Instrument Custer, powertrain control module. And it dropped from. 1.8 to 0.
Any ideas about #2?
With the battery disconnected, I removed the mentioned fuses that I thought pertained to #6 under the hood..
I closed the door, inserted the #6 under the hood, the drain is present.
I was hoping that by removing one of those 6 fuses, or all 6, would stop the drain.
Is it fair to say it is the pcm?
Oh, I see... It does both.
Pull the cluster and get a good lock at the back of it. See if you have any shorts or burnt leads.
Thank you, I will remove the instrument cluster and post pics tomorrow.
What if I disconnect the instrument cluster and retest with my multi, with all fuses back in.
This should confirm if it's draining my battery right?
I disconnected and removed the instrument cluster,
Put all fuses back in.
Retested with the multi.
I still have the battery drain.
I guess this implies it is my pcm?? since the issue is present with the cluster removed and those were the only 2 options according to the manual (pcm / cluster)
Any advice?
Any advice?
I noticed fuse 35 inside the car is for pcm, I removed it as well and the drain is still present.
I found in the manual a section for 'wiring diagram component location'
Component: Generic electronic module
Wiring diagram: Body Control modules, electronic suspension
I'll try and upload the 2 diagrams if anyone is familiar with wiring diagrams?
I can't make sense of it yet but I'm hoping someone here can
